Introdução
If the LED lights do not function after troubleshooting, you might need to change the LED Board. For this replacement you need a Phillips #2 screw driver and a metal spudger.
O que você precisa
Use a metal spudger to remove the top cover.
Use a Phillips #2 screwdriver to remove three 17 mm screws.
Quase terminado!
Conclusão
