Ir para o conteúdo principal
Harman Kardon Esquire Mini Front Panel Replacement
O que você precisa
  1. Harman Kardon Esquire Mini Front Panel Replacement, Front Panel: passo 1, imagem 1 %32
    • Using the plastic opening tool, to open the back panel of the device. Start on the longer sides to avoid bending the metal frame at the plug ports.
    • Push down on the plastic opening tool, and push the back panel, repeat this for the 4 sides of the device.
  2. Harman Kardon Esquire Mini Front Panel Replacement: passo 2, imagem 1 %32
    • Using the PH0 screw driver, remove the 7.5 mm screws by turning in a counter-clockwise direction. There are 6 screws on the front panel.
    • Remove all of the 7.5 mm screws, by repeating the same step above. It is not necessary to remove the stand-leg.
    • After unscrewing the 7.5 mm screws, just lift the plastic and you will see the motherboard.
Conclusão
Uma outra pessoa concluiu este guia.
yousef aljeemaz
Membro desde: 10/18/17
1.039 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G9, Cagle Fall 2017 Membro de USF Tampa, Team S1-G9, Cagle Fall 2017
USFT-CAGLE-F17S1G9
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 20
Duração total: 703
