Ir para o conteúdo principal
Apple Time Capsule Model A1254 Hard Drive Replacement
O que você precisa
  1. Apple Time Capsule Model A1254 Hard Drive Replacement, Back Plate: passo 1, imagem 1 %32 Apple Time Capsule Model A1254 Hard Drive Replacement, Back Plate: passo 1, imagem 2 %32 Apple Time Capsule Model A1254 Hard Drive Replacement, Back Plate: passo 1, imagem 3 %32
    • Turn the device upside down to reveal the rubber section of the back plate. Using a metal spudger, carefully wedge the blunt tip into the space between the aluminum back plate and the rubber, separating the two pieces.
    • This may take a few minutes to pry the rubber off completely. Once your are able to get a grip on the rubber it is easier to peel it off using your hands.
    • Depending on air temperature and how set the adhesive is, you may need to spend some time warming the back plate with a hot plate (on low) or hair dryer.
    • Don't worry about re-applying adhesive to the rubber; the remaining adhesive has plenty of strength to affix itself to the aluminum.
  2. Apple Time Capsule Model A1254 Hard Drive Replacement: passo 2, imagem 1 %32 Apple Time Capsule Model A1254 Hard Drive Replacement: passo 2, imagem 2 %32
    • Remove the ten 3mm screws with a Phillips #00 screwdriver.
    • The screws with adhesive covering do not need to be removed.
  3. Apple Time Capsule Model A1254 Hard Drive Replacement: passo 3, imagem 1 %32 Apple Time Capsule Model A1254 Hard Drive Replacement: passo 3, imagem 2 %32
    • The fan affixed to the back plate is connected to the logic board. A small wire must be detached to fully remove the back plate.
    • Pull the base of the wire close to the logic board and the connector will pop off.
  4. Apple Time Capsule Model A1254 Hard Drive Replacement, Hard Drive: passo 4, imagem 1 %32
    • Peel off the adhesive backed foam from the top of the drive.
    • Lift the drive straight up and out of the device.
  5. Apple Time Capsule Model A1254 Hard Drive Replacement: passo 5, imagem 1 %32 Apple Time Capsule Model A1254 Hard Drive Replacement: passo 5, imagem 2 %32 Apple Time Capsule Model A1254 Hard Drive Replacement: passo 5, imagem 3 %32
    • Remove the SATA connector and power connector from the end of the hard drive by simply pulling the cables straight away from the connection points.
Conclusão
33 outras pessoas executaram este guia.
Patrick Butler
Membro desde: 10/06/16
1.124 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 4-2, Livingston Fall 2016 Membro de Cal Poly, Team 4-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G2
Membros da 4
Autoria de 17 guias
10 comentários
What’s the max hard drive a Time Machine can take?
ice2257 - Responder
This answer: What's the biggest HDD that will fit on my Time Capsule? suggests that you can use pretty much any available drive. If it could take a 4TB in 2014 (one of the answers), I don’t think there would be any limit practically speaking.
odaiwai - Responder
Great guide. One note. My unit was quite old and the rubber mat was brittle. Even with a heat gun and spudger I still tore it in several places. This might be avoided by heating up a cloth in a microwave first and applying it to the rubber before beginning to pull it off. Just a thought.
wfstapleton - Responder
I’m not seeing a guide for the Apple Time Capsule 2TB MC344LLA / A1355 so I’ll have to see which one is closer to my model when it arrives,
But in the meantime has anyone been able to upgrade the hard drive past 2TB without any issues?
Is a Firmware update needed to do so?
David Bell - Responder
I installed a 3 TB about 7 years ago in mine. i’m here now because I can’t get it to power on.
Nubs34 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 28
Últimos 30 dias: 140
Duração total: 20,335
