Ir para o conteúdo principal
Hard Drive Backup
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
  1. Hard Drive Backup, Hard Drive Backup: passo 1, imagem 1 %32 Hard Drive Backup, Hard Drive Backup: passo 1, imagem 2 %32
    • If you need to backup the data on your current hard drive, follow the instructions in this step. Otherwise, continue to the next step.
    • On a Windows/OS X/Linux machine, format an external USB hard drive (with enough space available to backup your current hard content) into the FAT32 file system.
    • Make sure it's formatted FAT32. The Playstation 3 backup utility will not recognize any other file system.
    • Connect your formatted hard drive to the Playstation 3 through a USB port and power the console up.
    • Navigate the XMB to the 'Settings' menu and select 'System Settings'
    • Select the 'Backup Utility' function to create a backup of your data - this can take up to 2 hours if you have a lot of data on the PS3.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,785
