Ir para o conteúdo principal
Happimess 30 Liter Step Trash Can Lid Replacement
O que você precisa
  1. Happimess 30 Liter Step Trash Can Lid Replacement, Lid: passo 1, imagem 1 %32 Happimess 30 Liter Step Trash Can Lid Replacement, Lid: passo 1, imagem 2 %32
    • Before beginning the experiment, make sure to use gloves throughout the process to avoid contact with possible bacteria and corrosion.
    • Corrosion takes a hairy appearance but always avoid touching it with your bare hands as it can cause skin damage.
    • Using work gloves, remove the plastic bin from the metal bin.
  2. Happimess 30 Liter Step Trash Can Lid Replacement: passo 2, imagem 1 %32
    • Have someone hold their foot on the trash step to keep the lid open.
    • Another person may not be required, but it does help minimize complications when removing the lid.
  3. Happimess 30 Liter Step Trash Can Lid Replacement: passo 3, imagem 1 %32 Happimess 30 Liter Step Trash Can Lid Replacement: passo 3, imagem 2 %32
    • Locate two screws in the interior of the can.
    • Using a Phillips screwdriver, unscrew the two screws that hold the folding mechanism in place.
    • Do not attempt to unscrew the screws if they are frozen, you could end up stripping the screw which would make it almost impossible to remove.
    • If the screws are frozen and do not want to move, spray some WD40 or another lubricant around their heads to help loosen them.
  4. Happimess 30 Liter Step Trash Can Lid Replacement: passo 4, imagem 1 %32 Happimess 30 Liter Step Trash Can Lid Replacement: passo 4, imagem 2 %32
    • Locate the four tabs that hold the folding mechanism to the back of the can.
    • Use pliers to push all four plastic tabs inward until they pop out of the holes in the metal.
  5. Happimess 30 Liter Step Trash Can Lid Replacement: passo 5, imagem 1 %32 Happimess 30 Liter Step Trash Can Lid Replacement: passo 5, imagem 2 %32
    • Remove the trash can lid by pulling it to the left at a 45 degree angle.
    • When removed, place lid on a flat surface for the following steps.
  6. Happimess 30 Liter Step Trash Can Lid Replacement: passo 6, imagem 1 %32 Happimess 30 Liter Step Trash Can Lid Replacement: passo 6, imagem 2 %32
    • Locate the two screws that are holding the folding mechanism to the lid.
    • Use a Philips screwdriver to remove the two screws
  7. Happimess 30 Liter Step Trash Can Lid Replacement: passo 7, imagem 1 %32 Happimess 30 Liter Step Trash Can Lid Replacement: passo 7, imagem 2 %32 Happimess 30 Liter Step Trash Can Lid Replacement: passo 7, imagem 3 %32
    • Locate the two plastic tabs which are holding the fold mechanism to the lid.
    • Use pliers to push the two plastic tabs to the left.
    • This will separate the lid and the two plastic tabs which results in the lid being removed completely.
Conclusão
To reassemble your device with your new lid, follow these instructions in reverse order.
Max Butcher
Membro desde: 02/07/23
175 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 1-7, Andersen Winter 2023 Membro de UC Davis, Team 1-7, Andersen Winter 2023
UCD-ANDERSEN-W23S1G7
2 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 221
