Introdução
In this guide, you will learn how to find and replace your Wifi card. This solution may be more time consuming and difficult then simply buying a USB wifi adapter and using that instead.
O que você precisa
Locate the Wifi Card in the bottom right of the hard drive access panel.
Remove the two antenna plugged into the the Wifi Card.
Remove the two 3.6mm PH0 screws.
Quase terminado!
Conclusão
