Ir para o conteúdo principal
Hannspree SN12E2 Touchpad Plane/Keyboard Replacement
O que você precisa
  1. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Unplug and power off your laptop.
  2. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: passo 2, imagem 1 %32
    • Close your laptop .
    • Place your laptop face down on a flat surface.
  3. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: passo 3, imagem 1 %32 Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: passo 3, imagem 2 %32 Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: passo 3, imagem 3 %32
    • Unlatch the lock on the top right of your laptop first.
    • You will need to pull on the lock on the left side and remove the battery at the same time
    • The left lock is a spring lock and needs constant pressure applied in order to stay open.
  4. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement, Touchpad Plane/Keyboard: passo 4, imagem 1 %32
    • Remove all the 5mm PH0 screws on the back cover
  5. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: passo 5, imagem 1 %32 Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: passo 5, imagem 2 %32 Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: passo 5, imagem 3 %32
    • Gently pry the case apart starting at the lower right corner using the small spudger
    • Move around the case gently prying until the touchpad plane is free from the rest of the case
  6. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: passo 6, imagem 1 %32 Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: passo 6, imagem 2 %32
    • Gently lift up on the touchpad portion of the touchpad plane
    • Unplug the ZIFF connector by pulling gently on the black retaining blade and removing the white flat flex cable
    • Pull the touchpad away from the rest of the case
  7. Hannspree SN12E2 Touchpad Plane/Keyboard Replacement: passo 7, imagem 1 %32
    • Gently lift up on the loose keyboard to expose the ZIFF connector.
    • Unplug the keyboard ZIFF following the same instructions as the touchpad ZIFF
Conclusão
Tim Chase
Membro desde: 03/25/19
360 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 184
