Ir para o conteúdo principal
Hannspree Hannspad SN1AT71 Back Panel Replacement
O que você precisa
  1. Hannspree Hannspad SN1AT71 Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Back Panel Replacement: passo 2, imagem 1 %32 Hannspree Hannspad SN1AT71 Back Panel Replacement: passo 2, imagem 2 %32
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Back Panel Replacement: passo 3, imagem 1 %32
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Back Panel Replacement: passo 4, imagem 1 %32 Hannspree Hannspad SN1AT71 Back Panel Replacement: passo 4, imagem 2 %32
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Back Panel Replacement: passo 5, imagem 1 %32 Hannspree Hannspad SN1AT71 Back Panel Replacement: passo 5, imagem 2 %32
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
Conclusão
4 outras pessoas executaram este guia.
Equipe
Colorado Springs, Team 9-4, Panko Spring 2015 Membro de Colorado Springs, Team 9-4, Panko Spring 2015
UCCS-PANKO-S15S9G4
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 2,384
