Introdução
Replacing the capacitors on the power and/or the main board may fix issues like the monitor not powering on, the screen flickering on powering etc.
O que você precisa
Before you begin, be sure to unplug the device from the outlet.
First of all, you need to unscrew the 4 screws holding the stand. After that the 4 screws holding the back panel, they are located in the corners of the device (only the top ones are shown in the picture).
Second, you need to pry the plastic grey basel on the front of the monitor. There are several clips holding everything together.
Also after removing the basel it might be a good idea to give the screen a good clean.
First of all, disconnect all the connectors (5 marked with arrows.)
Second, remove the 4 acrews holding the bracket, marked with blue. (Also there might be some aluminum tape holding the covers, just rip it off, you wont need it for reassembly)
Third, remove the 4 screws covering the boards, marked with red.
After opening the cover, remove the 4 screws holding the power board and check for busted capacitors. (You might need to disconnect the connector, it might be easier for you to work)
In my case I had to change the 7 capacitors marked in red (the picture is after the change).
You can always put higher voltage (V) rated capacitors (if you have the space), but dont change the farad (F) rating.
Remove the 3 screws holding the main board and disconnect the 2 connectors
Unscrew the monitor connector stands so you can remove the board.
Flip the board and inspect the capacitors. In my case they were all fine (except the one marked in blue) and the monitor was working after I changed the capacitors on the power board, but yours may be different.
After putting everything back together, the monitor was working once again. I tested both display ports and the AUX port.
If fixing the capacitors didnt resolve your problem, please leave a comment.
Thank you for following my guide and I hope it helped you!
