Ir para o conteúdo principal
Handspring Visor Edge Screen Replacement
O que você precisa
  1. Handspring Visor Edge Screen Replacement, Flip Cover: passo 1, imagem 1 %32 Handspring Visor Edge Screen Replacement, Flip Cover: passo 1, imagem 2 %32
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Screen Replacement, Back Panel: passo 2, imagem 1 %32
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Screen Replacement: passo 3, imagem 1 %32
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Screen Replacement: passo 4, imagem 1 %32 Handspring Visor Edge Screen Replacement: passo 4, imagem 2 %32
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Screen Replacement: passo 5, imagem 1 %32 Handspring Visor Edge Screen Replacement: passo 5, imagem 2 %32
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Screen Replacement: passo 6, imagem 1 %32
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Screen Replacement, Screen: passo 7, imagem 1 %32
    • Place the PDA front face up.
    • Gently pull off the front cover.
  8. Handspring Visor Edge Screen Replacement: passo 8, imagem 1 %32 Handspring Visor Edge Screen Replacement: passo 8, imagem 2 %32
    • Flip over the PDA.
    • Use the tweezers to remove the ribbon cable attaching the screen to the circuit board.
  9. Handspring Visor Edge Screen Replacement: passo 9, imagem 1 %32 Handspring Visor Edge Screen Replacement: passo 9, imagem 2 %32
    • Wedge the spudger in between the glass and the metal frame.
    • Slide the spudger down the length of the screen to detach from the frame.
    • With your hands, pry the screen up from the detached side. The screen will pop off.
Conclusão
Christian Valoria
Membro desde: 01/23/11
201 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 11-28, Maness Winter 2011 Membro de Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 1,549
