Introdução
The button board can be easily pulled off without damaging the device. The only tool you need is a #00 Philips screwdriver.
O que você precisa
Open the Visor Edge and place it on a table facing down.
Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, and lift the pieces apart to detach them.
Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
Quase terminado!
Conclusão
