Introdução
The button board can be easily pulled off without damaging the device. The only tool you need is a #00 Philips screwdriver.
Peças
Não são necessárias peças.
  1. Place Visor Edge face down.
    • Place Visor Edge face down.
    • Notice the tab connecting the flip cover to the back of the PDA.
    • Gently push tab forward.
    • Do not pull on the flip cover to try and remove it from the PDA.
  2. Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
    • Remove the black plate from the PDA.
    • Remove four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the remaining 3.9 mm Philips screw holding together the stylus holster and the frame.
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
    • Remove the white frame from the PDA.
    • The frame may get stuck on the corners so be very gentle when working the corners off.
    • Pull off front cover gently.
    • Remove buttons by hand, they should come off easily.
Conclusão
Nick Lazarakis
334 reputação
3 Guides authored
Equipe
Cal Poly, Team 11-28, Maness Winter 2011 Membro de Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 Membros
7 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 619
