Introdução
Use this guide to replace the Touch Screen.
Peças
Não são necessárias peças.
  1. Remove the outer screen cover by releasing  the top clip from the main body of the device. Remove the outer screen cover by releasing  the top clip from the main body of the device.
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Pull out the stylus from the top right corner of the device. Pull out the stylus from the top right corner of the device. Pull out the stylus from the top right corner of the device.
    • Pull out the stylus from the top right corner of the device.
  3. Slide the memory cartridge cover up and off the device. Slide the memory cartridge cover up and off the device. Slide the memory cartridge cover up and off the device.
    • Slide the memory cartridge cover up and off the device.
  4. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  5. Remove the battery cover by releasing the clip from the main body of the device. Remove the battery cover by releasing the clip from the main body of the device.
    • Remove the battery cover by releasing the clip from the main body of the device.
  6. Remove the batteries from the device.
    • Remove the batteries from the device.
  7. Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  8. Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device. Be careful while opening the casing as there is a flex strip connecting the two halves. Be careful while opening the casing as there is a flex strip connecting the two halves.
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  9. Disconnect the flex strip from the motherboard with tweezers. Disconnect the flex strip from the motherboard with tweezers. Disconnect the flex strip from the motherboard with tweezers.
    • Disconnect the flex strip from the motherboard with tweezers.
  10. Release the latch in bottom right corner of the touchscreen. Use the spudger (if needed) to pry the screen from the front case. Use the spudger (if needed) to pry the screen from the front case.
    • Release the latch in bottom right corner of the touchscreen.
    • Use the spudger (if needed) to pry the screen from the front case.
Conclusão
David Faltemier
19 reputação
5 Guides authored
Equipe
Cal Poly, Team 1-2, Regan SU 2012 Membro de Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
4 Membros
6 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Todo: 530
