Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Handspring Visor Deluxe PDA Back Cover Replacement
O que você precisa
  1. Handspring Visor Deluxe PDA Back Cover Replacement, Outside cover and stylus: passo 1, imagem 1 %32 Handspring Visor Deluxe PDA Back Cover Replacement, Outside cover and stylus: passo 1, imagem 2 %32
    • Remove the outer screen cover by releasing the top clip from the main body of the device.
  2. Handspring Visor Deluxe PDA Back Cover Replacement: passo 2, imagem 1 %32 Handspring Visor Deluxe PDA Back Cover Replacement: passo 2, imagem 2 %32 Handspring Visor Deluxe PDA Back Cover Replacement: passo 2, imagem 3 %32
    • Pull out the stylus from the top right corner of the device.
  3. Handspring Visor Deluxe PDA Back Cover Replacement: passo 3, imagem 1 %32 Handspring Visor Deluxe PDA Back Cover Replacement: passo 3, imagem 2 %32 Handspring Visor Deluxe PDA Back Cover Replacement: passo 3, imagem 3 %32
    • Slide the memory cartridge cover up and off the device.
  4. Handspring Visor Deluxe PDA Back Cover Replacement, Batteries: passo 4, imagem 1 %32 Handspring Visor Deluxe PDA Back Cover Replacement, Batteries: passo 4, imagem 2 %32
    • Remove the battery cover by releasing the clip from the main body of the device.
  5. Handspring Visor Deluxe PDA Back Cover Replacement: passo 5, imagem 1 %32
    • Remove the batteries from the device.
  6. Handspring Visor Deluxe PDA Back Cover Replacement, Back Cover: passo 6, imagem 1 %32
    • Unscrew the four 2.94mm screws with a #00 Phillips screwdriver.
    • One end of the OEM stylus can unscrew and contains a mini #00 Phillips screwdriver.
  7. Handspring Visor Deluxe PDA Back Cover Replacement: passo 7, imagem 1 %32 Handspring Visor Deluxe PDA Back Cover Replacement: passo 7, imagem 2 %32 Handspring Visor Deluxe PDA Back Cover Replacement: passo 7, imagem 3 %32
    • Use the spudger to pry open the casing by applying pressure at 4 clips on both sides of the device.
    • Be careful while opening the casing as there is a flex strip connecting the two halves.
  8. Handspring Visor Deluxe PDA Back Cover Replacement: passo 8, imagem 1 %32 Handspring Visor Deluxe PDA Back Cover Replacement: passo 8, imagem 2 %32 Handspring Visor Deluxe PDA Back Cover Replacement: passo 8, imagem 3 %32
    • Disconnect the flex strip from the motherboard with tweezers.
Conclusão
Uma outra pessoa concluiu este guia.
Robert
Membro desde: 07/07/12
23 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 1-2, Regan SU 2012 Membro de Cal Poly, Team 1-2, Regan SU 2012
CPSU-REGAN-SU12S1G2
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 573
