Ir para o conteúdo principal
Hand-Held Blender Motor Replacement
O que você precisa
  1. Hand-Held Blender Motor Replacement, Motor: passo 1, imagem 1 %32
    • Place the product on a clean and empty surface.
  2. Hand-Held Blender Motor Replacement: passo 2, imagem 1 %32
    • Twist the attachment with the blades from the base of the blender.
  3. Hand-Held Blender Motor Replacement: passo 3, imagem 1 %32
    • Unscrew the Tri-point screw (2mm) on the top to disassemble the top part of the casing.
  4. Hand-Held Blender Motor Replacement: passo 4, imagem 1 %32
    • Unscrew the Phillips (2mm) connecting the middle part of the casing with the bottom part.
  5. Hand-Held Blender Motor Replacement: passo 5, imagem 1 %32
    • Use force to twist the middle part from the bottom part of the casing OR use spudgers to wiggle open the product.
    • This reveals the motor.
  6. Hand-Held Blender Motor Replacement: passo 6, imagem 1 %32
    • Lift the motor out of the casing.
    • Unscrew the Phillips (2mm) to disconnect the motor from the plastic part that transfers the motor rotations to the blade.
  7. Hand-Held Blender Motor Replacement: passo 7, imagem 1 %32
    • With a soldering iron disconnect the wires coming from the motor from the PCB.
    • Refer to this How to Solder and Desolder Connections guide to find more information on proper soldering techniques.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 69
Duração total: 3,287
