Ir para o conteúdo principal
Hamilton-T1 Air Intake and Fan Filter Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. Hamilton-T1 Air Intake and Fan Filter Replacement, Air Intakes and HEPA Filter: passo 1, imagem 1 %32
    • The fan filter is located on the side of the ventilator and can be removed and replaced by hand.
  2. Hamilton-T1 Air Intake and Fan Filter Replacement: passo 2, imagem 1 %32
    • The air intake filter is located on the rear of the device, and can also be removed by hand.
  3. Hamilton-T1 Air Intake and Fan Filter Replacement: passo 3, imagem 1 %32
    • To access the HEPA filter, first remove the screw holding the filter cover in place and gently remove the cover.
  4. Hamilton-T1 Air Intake and Fan Filter Replacement: passo 4, imagem 1 %32
    • The HEPA filter can now be removed by hand.
    • Install a new HEPA filter and reattach the back panel.
    • Be sure to test the device and ensure airflow through all filters before use.
Conclusão
Trevor Foley
Membro desde: 04/10/20
114 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S11-G24, Paton Spring 2020 Membro de Cal Poly, Team S11-G24, Paton Spring 2020
CPSU-PATON-S20S11G24
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 19
Duração total: 662
