Ir para o conteúdo principal
Hamilton Medical Ventilator Replacing the LCD
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. Hamilton Medical Ventilator Replacing the LCD, LCD: passo 1, imagem 1 %32
    • First open the main enclosure by removing the four hexagonal-drive (Allen) screws at the rear of the enclosure.
  2. Hamilton Medical Ventilator Replacing the LCD: passo 2, imagem 1 %32
    • Unscrew the control board mounting plate.
  3. Hamilton Medical Ventilator Replacing the LCD: passo 3, imagem 1 %32
    • “Hinge” back the mounting plate, complete with control board. This exposes the LCD.
  4. Hamilton Medical Ventilator Replacing the LCD: passo 4, imagem 1 %32
    • Unplug the cable from the GMP adaptor board from the LCD.
  5. Hamilton Medical Ventilator Replacing the LCD: passo 5, imagem 1 %32
    • Unplug from the dc/ac board, the cable to the interface board.
  6. Hamilton Medical Ventilator Replacing the LCD: passo 6, imagem 1 %32
    • Unscrew the four hexagonal-drive (Allen) screws securing the two brackets on which the LCD is mounted.
  7. Hamilton Medical Ventilator Replacing the LCD: passo 7, imagem 1 %32
    • Lift out the complete assembly.
  8. Hamilton Medical Ventilator Replacing the LCD: passo 8, imagem 1 %32
    • Unplug both of the lights from the dc/ac board.
  9. Hamilton Medical Ventilator Replacing the LCD: passo 9, imagem 1 %32
    • Remove the LCD from the two brackets, by removing the black hexagonal-drive (Allen) screws on the LCD. NOTE: Do not remove the silver hexagonal-drive (Allen) screws on the SIDE of the LCD.
  10. Hamilton Medical Ventilator Replacing the LCD: passo 10, imagem 1 %32
    • When fitting a new display, there must be an offset of approximately 2 mm between the plastic sealing strips on the LCD, and the brackets.
  11. Hamilton Medical Ventilator Replacing the LCD: passo 11, imagem 1 %32
    • If necessary, adjust this gap using the silver screws on the side of the LCD.
    • The surface of the LCD must be clean. Wipe it free of finger marks and dust with an antistatic paper towel.
  12. Hamilton Medical Ventilator Replacing the LCD: passo 13, imagem 1 %32
    • The cable from the GMP to the LCD must be in the cable grip on the control board mounting plate.
    • When screwing the LCD assembly into GALILEO, you must align it with the glass screen in GALILEO. Check this by looking at the front of GALILEO.
    • Turn on GALILEO, and make sure that the LCD lights up, and is properly aligned.
Conclusão
Sofya Shatalova
Membro desde: 04/07/20
229 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S7-G26, Paton Spring 2020 Membro de Cal Poly, Team S7-G26, Paton Spring 2020
CPSU-PATON-S20S7G26
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 8
Duração total: 251
