Ir para o conteúdo principal
Hamilton Galileo Ventilator Power Supply Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. Hamilton Galileo Ventilator Power Supply Replacement, Opening the Column in the Hamilton Galileo: passo 1, imagem 1 %32
    • Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
    • Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
  2. Hamilton Galileo Ventilator Power Supply Replacement: passo 3, imagem 1 %32
    • Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
  3. Hamilton Galileo Ventilator Power Supply Replacement: passo 4, imagem 1 %32 Hamilton Galileo Ventilator Power Supply Replacement: passo 4, imagem 2 %32
    • Without removing any electrical connections, open the left side of the column as wide as practical.
    • This exposes: GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    • Make sure no electrical connections are touching the column.
    • Make sure all green/brown grounding (earthing) cables are securely in place.
  4. Hamilton Galileo Ventilator Power Supply Replacement, Power Supply: passo 6, imagem 1 %32 Hamilton Galileo Ventilator Power Supply Replacement, Power Supply: passo 6, imagem 2 %32
    • Remove all cables connecting power supply to GALILEO.
    • To remove the main power connector, squeeze on the two points indicated in the second picture.
    • Remove the rear cover and place it on a suitable surface.
  5. Hamilton Galileo Ventilator Power Supply Replacement: passo 8, imagem 1 %32
    • Unscrew the retaining strip securing the power supply in its housing.
  6. Hamilton Galileo Ventilator Power Supply Replacement: passo 9, imagem 1 %32
    • Slide the power supply out from its housing.
  7. Hamilton Galileo Ventilator Power Supply Replacement: passo 10, imagem 1 %32 Hamilton Galileo Ventilator Power Supply Replacement: passo 10, imagem 2 %32
    • To install the new power supply, simply do steps 5-2 in reverse.
    • Make sure the security clamp (shown in picture) is tight before reinstalling power supply.
    • Perform the internal voltage test linked here: page 7-5 of Section 7.3, Checking voltages.
    • If this test is not successful, it is likely that there is a loose connection somewhere between the internal power supply and the printed circuit boards. Check the wires to make sure they are securely fastened.
    • When the above test is successful, continue with the tests in the following sections:
    • 1) Section7, Checking hardware, voltages, and interface
    • 2) Either: Section 9, Running Original Upgrade 1 test software OR Section 10, Running Upgrade 2 test software
Conclusão
Uma outra pessoa concluiu este guia.
Ian Van Sciver
Membro desde: 04/09/20
332 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S7-G26, Paton Spring 2020 Membro de Cal Poly, Team S7-G26, Paton Spring 2020
CPSU-PATON-S20S7G26
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 546
