Introdução
These instructions detail how to replace both the control board and the GMP assembly. The need to replace the control board is rare. However, in the event of a major product update it may be necessary to do. For more information on replacing the control board and the GMP assembly, please refer to page 11-52 in the full service manual.
O que você precisa
Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
To reassemble, mount the control board back onto plastic spacers without using pliers and be sure to connect all cables together correctly.
