Ir para o conteúdo principal
Hamilton G5 Inspiratory Valve Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
O que você precisa
  1. Hamilton G5 Inspiratory Valve Replacement, Rail: passo 1, imagem 1 %32
    • Remove 4 Hex Allen screws (A) from the Rail surrounding the Ventilation Unit.
  2. Hamilton G5 Inspiratory Valve Replacement: passo 2, imagem 1 %32
    • Remove the Rail (B).
  3. Hamilton G5 Inspiratory Valve Replacement: passo 3, imagem 1 %32
    • The Standoff Brackets (C) remain with the Main Cover.
    • Place aside in a safe location.
  4. Hamilton G5 Inspiratory Valve Replacement, Main Cover: passo 5, imagem 1 %32
    • Lift the Main Cover (A) from the Ventilation Unit using the Standoff Brackets (B) attached to the Main Cover.
  5. Hamilton G5 Inspiratory Valve Replacement, Safety Valve Block: passo 7, imagem 1 %32
    • Remove Safety Valve Block
    • 1. Disconnect the cable from the Ambient Valve Solenoid
    • 2. Disconnect the Shaped Hose (A)
    • 3. Remove the 2 Hex Allen Screws (B)
    • 4. Remove the Safety Valve Block
    • To remove Ambient Valve Solenoid: Unscrew the Ambient Valve Solenoid (C) form the Safety Valve Block
  6. Hamilton G5 Inspiratory Valve Replacement, Inspiratory Valve: passo 8, imagem 1 %32 Hamilton G5 Inspiratory Valve Replacement, Inspiratory Valve: passo 8, imagem 2 %32
    • Removing the Inspiration Valve
    • 1. Disconnect the tubing and cables form the Inspiration Valve
    • 3. Remove 2 Hex Allen screws (B) M5x60
    • 4. Move the Inspiration Valve forward and then up
    • 5. Remove the Inspiration Valve
Conclusão
William
Membro desde: 04/09/20
145 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team S7-G25, Paton Spring 2020 Membro de Cal Poly, Team S7-G25, Paton Spring 2020
CPSU-PATON-S20S7G25
Membros da 6
Autoria de 11 guias
Um comentário
wow great manual! very helpful and informative!
William - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 257
