Ir para o conteúdo principal
Hamilton Beach 70740 Power Cord Replacement
O que você precisa
  1. Hamilton Beach 70740 Power Cord Replacement, Bowl and Lid: passo 1, imagem 1 %32 Hamilton Beach 70740 Power Cord Replacement, Bowl and Lid: passo 1, imagem 2 %32
    • Turn the bowl counterclockwise and lift.
  2. Hamilton Beach 70740 Power Cord Replacement, Base: passo 2, imagem 1 %32 Hamilton Beach 70740 Power Cord Replacement, Base: passo 2, imagem 2 %32
    • Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
    • Pull suction cups straight out.
  3. Hamilton Beach 70740 Power Cord Replacement: passo 3, imagem 1 %32 Hamilton Beach 70740 Power Cord Replacement: passo 3, imagem 2 %32 Hamilton Beach 70740 Power Cord Replacement: passo 3, imagem 3 %32
    • Remove rubber caps using the heavy duty spudger.
    • Remove the four 11 mm screws using the #2 Phillips head screwdriver.
    • Pull base straight out.
  4. Hamilton Beach 70740 Power Cord Replacement, Power Cord: passo 4, imagem 1 %32 Hamilton Beach 70740 Power Cord Replacement, Power Cord: passo 4, imagem 2 %32 Hamilton Beach 70740 Power Cord Replacement, Power Cord: passo 4, imagem 3 %32
    • Using a #2 Phillips head screwdriver, remove the four 9 mm screws.
    • From the open base pull the motor straight out.
  5. Hamilton Beach 70740 Power Cord Replacement: passo 5, imagem 1 %32
    • Using the wire stripper crimping tool cut the black wire connection from the power cord to the motor and then rewire the new power cord to the motor.
  6. Hamilton Beach 70740 Power Cord Replacement: passo 6, imagem 1 %32 Hamilton Beach 70740 Power Cord Replacement: passo 6, imagem 2 %32
    • Remove the two 12 mm screws using the #2 Phillips head screwdriver.
    • Remove plastic piece.
  7. Hamilton Beach 70740 Power Cord Replacement: passo 7, imagem 1 %32 Hamilton Beach 70740 Power Cord Replacement: passo 7, imagem 2 %32
    • Remove the three 12 mm screws using the #2 Phillips head screwdriver.
    • Remove the plastic piece by pulling straight up.
  8. Hamilton Beach 70740 Power Cord Replacement: passo 8, imagem 1 %32 Hamilton Beach 70740 Power Cord Replacement: passo 8, imagem 2 %32
    • Remove the power cord from the ground by removing the solder with the soldering tool.
    • Solder the new ground from the new power cord.
Conclusão
Uma outra pessoa concluiu este guia.
Travis Williams
Membro desde: 02/02/17
552 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 17-4, Blackwell Spring 2017 Membro de USF Tampa, Team 17-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G4
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 821
