Ir para o conteúdo principal
Hamilton Beach 70740 Motor Replacement
O que você precisa
  1. Hamilton Beach 70740 Motor Replacement, Bowl and Lid: passo 1, imagem 1 %32 Hamilton Beach 70740 Motor Replacement, Bowl and Lid: passo 1, imagem 2 %32
    • Turn the bowl counterclockwise and lift.
  2. Hamilton Beach 70740 Motor Replacement, Gears: passo 2, imagem 1 %32 Hamilton Beach 70740 Motor Replacement, Gears: passo 2, imagem 2 %32
    • Use the nylon spudger to remove the plastic screw covers.
  3. Hamilton Beach 70740 Motor Replacement: passo 3, imagem 1 %32 Hamilton Beach 70740 Motor Replacement: passo 3, imagem 2 %32 Hamilton Beach 70740 Motor Replacement: passo 3, imagem 3 %32
    • Using a #2 Phillips head screwdriver, remove the four 10 mm screws and pull the shaft straight upwards to uncover gears.
  4. Hamilton Beach 70740 Motor Replacement: passo 4, imagem 1 %32 Hamilton Beach 70740 Motor Replacement: passo 4, imagem 2 %32
    • Firmly grasp center piece of gear mechanism and pull straight upward.
  5. Hamilton Beach 70740 Motor Replacement, Motor: passo 5, imagem 1 %32 Hamilton Beach 70740 Motor Replacement, Motor: passo 5, imagem 2 %32
    • Using a #2 Phillips head screwdriver, remove the two 11 mm screws and pull the rubber suction cups straight up.
  6. Hamilton Beach 70740 Motor Replacement: passo 6, imagem 1 %32 Hamilton Beach 70740 Motor Replacement: passo 6, imagem 2 %32 Hamilton Beach 70740 Motor Replacement: passo 6, imagem 3 %32
    • Using the heavy duty plastic spudger remove the four rubber caps.
    • Using a #2 Phillips head screwdriver, remove the four 11 mm screws inside each of the bases legs.
    • Pull the base straight up to remove it from the processor.
  7. Hamilton Beach 70740 Motor Replacement: passo 7, imagem 1 %32 Hamilton Beach 70740 Motor Replacement: passo 7, imagem 2 %32 Hamilton Beach 70740 Motor Replacement: passo 7, imagem 3 %32
    • Using a #2 Phillips head screwdriver, remove the four 9 mm screws.
    • From the open base pull the motor straight out.
  8. Hamilton Beach 70740 Motor Replacement: passo 8, imagem 1 %32 Hamilton Beach 70740 Motor Replacement: passo 8, imagem 2 %32
    • Using the wire stripper crimping tool cut the black wire connection from the power cord to the motor.
    • Using the wire stripper crimping tool strip the ends of each of the black cords and insert them into the opposite ends of a parallel connector, then crimp firmly.
    • Using the wire stripper crimping tool cut the four red wire connections from the switch to the motor and then rewire the four red wires together in a wiring connector cap.
    • Using the wire stripper crimping tool strip the ends of each red wire and insert them into a new wiring connector cap, then crimp firmly.
Conclusão
Uma outra pessoa concluiu este guia.
Travis Williams
Membro desde: 02/02/17
552 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 17-4, Blackwell Spring 2017 Membro de USF Tampa, Team 17-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G4
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 3,006
