Introdução
Be sure to keep the processor unplugged throughout the replacement process.
Ferramentas
Peças
Nenhum componente especificado.
Using the heavy duty spudger pry the plastic knob off the front of the processor.
Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
Pull suction cups straight out.
Cut all four red wires using the wire stripper crimping tool.
Using the wire stripper crimping tool strip the ends of each red wire and insert them into a new wiring connector cap, then crimp firmly.
Cut the white wire using the stripper crimping tool.
Using the wire stripper crimping tool strip the ends of each of the white wires and insert them into the opposite ends of a parallel connector, then crimp firmly.
Um comentário
On our unit the control knob became stuck. Where can I get a new control knob? Do you happen to know the part number?
