Introdução
Replacing of processor base. Be sure the processor is unplugged before beginning.
O que você precisa
Using a #2 Phillips head screwdriver, remove the two 11 mm screws from the base.
Pull suction cups straight out.
Remove rubber caps using the heavy duty spudger.
Remove the four 11 mm screws using the #2 Phillips head screwdriver.
Pull base straight out.
Quase terminado!
Conclusão
