Ir para o conteúdo principal
Hamilton Beach 64650 Mixer Release Button Replacement
O que você precisa
  1. Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: passo 1, imagem 1 %32 Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: passo 1, imagem 2 %32 Hamilton Beach 64650 Mixer Release Button Replacement, Mixer Release Button: passo 1, imagem 3 %32
    • Depress mixer release button fully and lift mixer off of the platform.
    • Remove the bowl from the stand.
  2. Hamilton Beach 64650 Mixer Release Button Replacement: passo 2, imagem 1 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 2, imagem 2 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 2, imagem 3 %32
    • Remove and set aside the three 1.3 mm Philips #2 screws holding the plastic cover in place.
  3. Hamilton Beach 64650 Mixer Release Button Replacement: passo 3, imagem 1 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 3, imagem 2 %32
    • Shift the cover to allow the plastic retaining hook to fit through the hole easily.
    • Lift the cover away.
  4. Hamilton Beach 64650 Mixer Release Button Replacement: passo 4, imagem 1 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 4, imagem 2 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 4, imagem 3 %32
    • Fully depress the mixer release button, pushing it through the mounting hole.
    • Push the button slightly upwards once it is inside the stand to access the spring underneath it.
    • Carefully remove the button from the stand while leaving spring in place.
  5. Hamilton Beach 64650 Mixer Release Button Replacement: passo 5, imagem 1 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 5, imagem 2 %32 Hamilton Beach 64650 Mixer Release Button Replacement: passo 5, imagem 3 %32
    • Depress the spring slightly and lift upward to remove.
    • Replace with a new spring to have a working button again.
Conclusão
Gwen Davis
Membro desde: 03/24/16
519 Reputação
Autoria de 5 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 25
Ao todo: 1,428
