Ir para o conteúdo principal
Hamilton Beach 48464 Tubing Replacement
O que você precisa
  1. Hamilton Beach 48464 Tubing Replacement, Filter Basket: passo 1, imagem 1 %32 Hamilton Beach 48464 Tubing Replacement, Filter Basket: passo 1, imagem 2 %32
    • Carefully open the top lid of the Brew Station.
  2. Hamilton Beach 48464 Tubing Replacement: passo 2, imagem 1 %32
    • Slide out the filter basket that is sitting on top after opening the lid.
  3. Hamilton Beach 48464 Tubing Replacement, Tubing: passo 3, imagem 1 %32 Hamilton Beach 48464 Tubing Replacement, Tubing: passo 3, imagem 2 %32
    • Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline.
    • Once screws are removed, pull off the little circle piece.
  4. Hamilton Beach 48464 Tubing Replacement: passo 4, imagem 1 %32 Hamilton Beach 48464 Tubing Replacement: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, grab the tube that is exposed after you pulled the piece off in step 1 and pull it up and out of the Brew Station.
  5. Hamilton Beach 48464 Tubing Replacement: passo 5, imagem 1 %32 Hamilton Beach 48464 Tubing Replacement: passo 5, imagem 2 %32
    • Using the Philips 2 Screwdriver, unscrew the three 8-mm screws labeled in a red outline.
    • Once screws are removed, gently pull off the liner that is on the inside of the lid.
  6. Hamilton Beach 48464 Tubing Replacement: passo 6, imagem 1 %32 Hamilton Beach 48464 Tubing Replacement: passo 6, imagem 2 %32
    • After completing Step 3, you will be exposed to a little piece attached to the inside of the lid. Pull this piece out, as it is the last piece of tubing used in the Brew Station.
Conclusão
Michael Damico
Membro desde: 02/10/16
661 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 14-1, Lacy Spring 2016 Membro de USF Tampa, Team 14-1, Lacy Spring 2016
USFT-LACY-S16S14G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 779
