Introdução
This guide shows you how to remove the tubing found inside the Brew Station. This is helpful when you want to replace it for a cleaner tube. Tweezers for the removal of the tube is highly suggested.
O que você precisa
Using the Philips 2 Screwdriver, unscrew the two 8-mm screws labeled in a red outline.
Once screws are removed, pull off the little circle piece.
Quase terminado!
Conclusão
