Ir para o conteúdo principal
Hamilton Beach 48464 Heating Plate Replacement
O que você precisa
  1. Hamilton Beach 48464 Heating Plate Replacement, Heating Plate: passo 1, imagem 1 %32
    • To begin, carefully open the top lid of the Brew Station.
  2. Hamilton Beach 48464 Heating Plate Replacement: passo 2, imagem 1 %32
    • Gently pull out the filter basket from the Brew Station and set it to the side.
  3. Hamilton Beach 48464 Heating Plate Replacement: passo 3, imagem 1 %32
    • Grab the handle and pull up to remove the top container.
    • Set this piece close by as you will be needing it for a future step.
  4. Hamilton Beach 48464 Heating Plate Replacement: passo 4, imagem 1 %32 Hamilton Beach 48464 Heating Plate Replacement: passo 4, imagem 2 %32
    • Using the Crown Bolt #8 Steel Spanner, unscrew the four 8-mm screws labeled in a red outline.
  5. Hamilton Beach 48464 Heating Plate Replacement: passo 5, imagem 1 %32 Hamilton Beach 48464 Heating Plate Replacement: passo 5, imagem 2 %32
    • Check again to make sure that the coffee maker is not plugged in.
    • Once the screws are removed, carefully pull off the metal piece.
    • Once the piece is removed, you will be able to access the heater.
  6. Hamilton Beach 48464 Heating Plate Replacement: passo 6, imagem 1 %32 Hamilton Beach 48464 Heating Plate Replacement: passo 6, imagem 2 %32
    • This step involves using the top contained that you put aside in step 3.
    • Using the Philips 2 Screwdriver, unscrew the eight 8-mm screws labeled in a red outline.
  7. Hamilton Beach 48464 Heating Plate Replacement: passo 7, imagem 1 %32
    • Once screws are removed, carefully pull out the metal piece from the unit. This is the top part of the heater in the Brew Staton.
    • There are rubber washers inside each of the 8 holes on the piece of metal. Be careful to not let any fall out when handling the piece.
Conclusão
Uma outra pessoa concluiu este guia.
Michael Damico
Membro desde: 02/10/16
661 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 14-1, Lacy Spring 2016 Membro de USF Tampa, Team 14-1, Lacy Spring 2016
USFT-LACY-S16S14G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 976
