Introdução
This is a straight-forward process that requires removal of washers and bolts.
The handle can be removed if it needs to be replaced, or to make access to the top heating element housing easier.
O que você precisa
On the back of the press, remove the locking washer by prying upwards with the nylon or metal spudger tool.
Repeat for the other washer across from the first one.
Quase terminado!
Conclusão
