Ir para o conteúdo principal
Halloween Witch Doctor Dancing Dog Broken Gear Replacement
  1. Halloween Witch Doctor Dancing Dog Broken Gear Replacement, Remove blind stitch to access mechanism.: passo 1, imagem 1 %32
    • The bottom plate is removable, but doesn't give you access to the mechanism.
    • Blind stitch looks different from other seams in fabric.
  2. Halloween Witch Doctor Dancing Dog Broken Gear Replacement, Remove ear mechanism: passo 2, imagem 1 %32 Halloween Witch Doctor Dancing Dog Broken Gear Replacement, Remove ear mechanism: passo 2, imagem 2 %32
    • If you look closely at gear, you can see a small crack
    • I bought an assortment of plastic gears from Amazon because I wasn't sure of the size. https://www.amazon.com/gp/product/B075QY...
    • I ending up using an 8 tooth, 2mm shaft, 0.5 modulus gear. That is, an 82A white plastic gear.
Conclusão
Here is a video of it working again!
https://www.youtube.com/shorts/AESLgu-wI...
Alan Nishioka
Membro desde: 07/17/11
3.507 Reputação
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 58
