Ir para o conteúdo principal
HUAWEI HONOR 5X Vibration Motor Replacement
O que você precisa
  1. HUAWEI HONOR 5X Vibration Motor Replacement, HUAWEI HONOR 5X Disassembly: passo 1, imagem 1 %32
    • Turn off your cell phone before disassembling.
  2. HUAWEI HONOR 5X Vibration Motor Replacement: passo 2, imagem 1 %32
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. HUAWEI HONOR 5X Vibration Motor Replacement: passo 3, imagem 1 %32 HUAWEI HONOR 5X Vibration Motor Replacement: passo 3, imagem 2 %32
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. HUAWEI HONOR 5X Vibration Motor Replacement: passo 4, imagem 1 %32
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. HUAWEI HONOR 5X Vibration Motor Replacement: passo 5, imagem 1 %32 HUAWEI HONOR 5X Vibration Motor Replacement: passo 5, imagem 2 %32
    • Pry off the back with a plastic opening tool.
  6. HUAWEI HONOR 5X Vibration Motor Replacement, Motherboard: passo 6, imagem 1 %32 HUAWEI HONOR 5X Vibration Motor Replacement, Motherboard: passo 6, imagem 2 %32
    • Remove the five 1.5mm Phillips #000 screws from the motherboard.
  7. HUAWEI HONOR 5X Vibration Motor Replacement: passo 7, imagem 1 %32 HUAWEI HONOR 5X Vibration Motor Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a plastic opening tool to pry up and disconnect the display cable from the motherboard.
    • Use tweezers to disconnect the white coax cable.
    • Use tweezers to disconnect the power and volume cable.
  8. HUAWEI HONOR 5X Vibration Motor Replacement: passo 8, imagem 1 %32 HUAWEI HONOR 5X Vibration Motor Replacement: passo 8, imagem 2 %32 HUAWEI HONOR 5X Vibration Motor Replacement: passo 8, imagem 3 %32
    • Remove the motherboard.
  9. HUAWEI HONOR 5X Vibration Motor Replacement, Vibration Motor: passo 9, imagem 1 %32 HUAWEI HONOR 5X Vibration Motor Replacement, Vibration Motor: passo 9, imagem 2 %32
    • Using the metal spudger, pry the adhered vibration monitor to remove.
    • Using the metal spudger may damage the internal components of your device, so please use the plastic spudger or opening tool instead.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 254
