Ir para o conteúdo principal
HUAWEI HONOR 5X Charging Port Replacement
O que você precisa
  1. HUAWEI HONOR 5X Charging Port Replacement, HUAWEI HONOR 5X Disassembly: passo 1, imagem 1 %32
    • Turn off your cell phone before disassembling.
  2. HUAWEI HONOR 5X Charging Port Replacement: passo 2, imagem 1 %32
    • Remove the two 1.17mm Torx T3 screws from the bottom of the phone.
  3. HUAWEI HONOR 5X Charging Port Replacement: passo 3, imagem 1 %32 HUAWEI HONOR 5X Charging Port Replacement: passo 3, imagem 2 %32
    • Use the Sim card ejection tool to remove both the sim card trays.
  4. HUAWEI HONOR 5X Charging Port Replacement: passo 4, imagem 1 %32
    • To prepare the iOpener insert it in the microwave for 30 seconds and apply it on the side edges of the phone so that the glue underneath will soften.
  5. HUAWEI HONOR 5X Charging Port Replacement: passo 5, imagem 1 %32 HUAWEI HONOR 5X Charging Port Replacement: passo 5, imagem 2 %32
    • Pry off the back with a plastic opening tool.
  6. HUAWEI HONOR 5X Charging Port Replacement, Charging Port: passo 6, imagem 1 %32 HUAWEI HONOR 5X Charging Port Replacement, Charging Port: passo 6, imagem 2 %32
    • Remove the six 1.5mm Phillips #000 screws from the bottom of the phone.
  7. HUAWEI HONOR 5X Charging Port Replacement: passo 7, imagem 1 %32 HUAWEI HONOR 5X Charging Port Replacement: passo 7, imagem 2 %32
    • Use a plastic opening tool to disconnect the white and black antenna cables from the daughterboard.
  8. HUAWEI HONOR 5X Charging Port Replacement: passo 8, imagem 1 %32
    • Remove the daughterboard.
Conclusão
Klara Asllani
Membro desde: 01/25/18
788 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S7-G6, Passmore Spring 2018 Membro de USF Tampa, Team S7-G6, Passmore Spring 2018
USFT-PASSMORE-S18S7G6
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 1,677
