Introdução
This guide will help you clean or replace your HTC myTouch 3G trackball safely and effectively.
O que você precisa
Slide the back cover down to remove it.
Lift and remove the battery. Then remove the SIM card by sliding it out of its slot.
Locate SD card on the lower right. Press in to eject and remove it.
Uma outra pessoa concluiu este guia.
