Introdução
Takes you through the steps to install the speakers.
O que você precisa
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
Remove the four 6 mm screws with the T5 Torx screwdriver.
Quase terminado!
Conclusão
