Ir para o conteúdo principal
HTC Wizard 200 Motherboard Replacement
O que você precisa
  1. HTC Wizard 200 Motherboard Replacement, Battery: passo 1, imagem 1 %32 HTC Wizard 200 Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • To expose the battery, remove the outer case with your fingernail.
    • Remove the battery by pulling the black tab.
  2. HTC Wizard 200 Motherboard Replacement, Back Panel: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Spudger
    $3.99
    Comprar
    • Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
  3. HTC Wizard 200 Motherboard Replacement: passo 3, imagem 1 %32 HTC Wizard 200 Motherboard Replacement: passo 3, imagem 2 %32
    Spudger
    $3.99
    Comprar
    • Work the spudger around the edges of the camera cover until it comes off.
  4. HTC Wizard 200 Motherboard Replacement: passo 4, imagem 1 %32 HTC Wizard 200 Motherboard Replacement: passo 4, imagem 2 %32
    T5 Torx Screwdriver
    $5.49
    Comprar
    • Remove the four 6 mm screws with the T5 Torx screwdriver.
    • One of the screws is under the "void" sticker.
  5. HTC Wizard 200 Motherboard Replacement: passo 5, imagem 1 %32 HTC Wizard 200 Motherboard Replacement: passo 5, imagem 2 %32 HTC Wizard 200 Motherboard Replacement: passo 5, imagem 3 %32
    • Insert the flat end of an iFixit opening tool between the side and inner covers to create a gap.
    • Work the tool around the edges until all the clips release.
  6. HTC Wizard 200 Motherboard Replacement: passo 6, imagem 1 %32 HTC Wizard 200 Motherboard Replacement: passo 6, imagem 2 %32
    • Once all the clips are open, remove the inner panel from the phone.
  7. HTC Wizard 200 Motherboard Replacement, Motherboard: passo 7, imagem 1 %32
    Spudger
    $3.99
    Comprar
    • Use the spudger to pry the camera off.
  8. HTC Wizard 200 Motherboard Replacement: passo 8, imagem 1 %32 HTC Wizard 200 Motherboard Replacement: passo 8, imagem 2 %32
    Comprar
    • Using tweezers, flip the connector latch away from the motherboard.
    • Detach the flexible connection from under the connector latch.
  9. HTC Wizard 200 Motherboard Replacement: passo 9, imagem 1 %32
    • Slide the keyboard into the open position.
  10. HTC Wizard 200 Motherboard Replacement: passo 10, imagem 1 %32 HTC Wizard 200 Motherboard Replacement: passo 10, imagem 2 %32
    Spudger
    $3.99
    Comprar
    • Lift the motherboard out of the case using the spudger.
    • Expose the underside of the motherboard using your hands.
  11. HTC Wizard 200 Motherboard Replacement: passo 11, imagem 1 %32 HTC Wizard 200 Motherboard Replacement: passo 11, imagem 2 %32
    • Remove the flexible connection from the motherboard.
    • Caution: Removing the connection too fast may cause damage to the connection and cables.
Conclusão
Kyle Champ
Membro desde: 10/03/11
225 Reputação
Autoria de 12 guias
Equipe
Cal Poly, Team 20-27, Maness Fall 2011 Membro de Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
Membros da 4
Autoria de 24 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,102
