Pular para o conteúdo principal
Introdução
This guide will display how to remove and install the back panel of the HTC Wizard 200.
  1. Remove the back case with your fingernail to expose the battery. (Not shown in picture) Pull the black tab to remove the battery.
    • Remove the back case with your fingernail to expose the battery. (Not shown in picture)
    • Pull the black tab to remove the battery.
  2. Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
    • Use a spudger to begin removal of the camera cover by inserting the flat end into the two notches and gently pry them up one at a time.
  3. Work the spudger around the edge of the camera cover to release the clips. Work the spudger around the edge of the camera cover to release the clips.
    • Work the spudger around the edge of the camera cover to release the clips.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
    • Use a T5 Torx screwdriver to remove four 6mm screws that secure the back panel to the main body.
    • There is a screw under the "void" sticker.
  5. Device rotated 180 degrees. Insert the flat end of a spudger into the crack between the front and rear cover.
    • Device rotated 180 degrees.
    • Insert the flat end of a spudger into the crack between the front and rear cover.
    • Once you have enough of a gap to fit a plastic opening tool into it, use the opening tool to release the clips.
  6. Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge. Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
    • Use the plastic opening tool to continue releasing the clips until you have worked your way around the edge.
  7. Pull off the back case panel. Pull off the back case panel.
    • Pull off the back case panel.
Conclusão
Kyle Champ
Membro desde: 03-10-2011
204 reputação
12 Guias de autoria
Equipe
Cal Poly, Team 20-27, Maness Fall 2011 Membro de Cal Poly, Team 20-27, Maness Fall 2011
CPSU-MANESS-F11S20G27
4 Membros
12 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Todo: 1,013
