Ir para o conteúdo principal
HTC Wizard 100 Speakers Replacement
O que você precisa
  1. HTC Wizard 100 Speakers Replacement, Battery: passo 1, imagem 1 %32 HTC Wizard 100 Speakers Replacement, Battery: passo 1, imagem 2 %32
    • Power the phone off.
    • Use your thumb to gently press downward and away from the camera to remove the battery cover.
  2. HTC Wizard 100 Speakers Replacement: passo 2, imagem 1 %32 HTC Wizard 100 Speakers Replacement: passo 2, imagem 2 %32
    • Pull on the plastic tab to release the battery.
  3. HTC Wizard 100 Speakers Replacement, Back Case: passo 3, imagem 1 %32 HTC Wizard 100 Speakers Replacement, Back Case: passo 3, imagem 2 %32
    • Use a plastic opening tool to remove the camera cover.
    • Work around the corners to avoid breaking the plastic clips that hold the camera cover on.
    • Lift the camera cover off of the phone.
  4. HTC Wizard 100 Speakers Replacement: passo 4, imagem 1 %32
    • Remove the stylus from the phone.
    • Remove the four 5.5 mm screws with the T6 Torx Screwdriver.
    • One of the screws might be under a sticker, which will void your warranty.
  5. HTC Wizard 100 Speakers Replacement: passo 5, imagem 1 %32 HTC Wizard 100 Speakers Replacement: passo 5, imagem 2 %32 HTC Wizard 100 Speakers Replacement: passo 5, imagem 3 %32
    • Be Careful! Do not insert the spudger in between the keyboard and screen. This could break the keyboard off the phone.
    • If your phone contains a memory card, you may want to remove it before proceeding with this step.
    • Insert spudger in the bottom corner as seen in the picture. Carefully slide the spudger from the bottom towards the top as seen in the second picture.
    • Lift the back case off completely.
    • The speakers might be dangling and unsecured.
  6. HTC Wizard 100 Speakers Replacement, Speakers: passo 6, imagem 1 %32 HTC Wizard 100 Speakers Replacement, Speakers: passo 6, imagem 2 %32
    • Grip the speaker connector with your thumb and finger and gently pull up.
    • Repeat for 2nd speaker.
Conclusão
Taylor Stone
Membro desde: 10/06/11
45 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 20-28, Maness Fall 2011 Membro de Cal Poly, Team 20-28, Maness Fall 2011
CPSU-MANESS-F11S20G28
4 Membros
Autoria de 15 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 56
Ao todo: 825
