Introdução
How to replace the battery on HTC 8S.
O que você precisa
Vídeo de Apresentação
Switch off the phone.
Remove the SIM / memory card cover.
Remove any SIM and memory cards.
Use screwdriver torx T5 and unscrew the two screws at the bottom of the battery / back cover.
Use a Phillips #0 screwdriver and remove the 4x silver screws.
With a plastic tool carefully separate the battery from the logic board.
3 outras pessoas executaram este guia.
