Ir para o conteúdo principal
HTC Warhawk Buttons Replacement
O que você precisa
  1. HTC Warhawk Buttons Replacement, Buttons: passo 1, imagem 1 %32
    • Take the back cover off the phone and take the battery out.
  2. HTC Warhawk Buttons Replacement: passo 2, imagem 1 %32
    • Take a SL#2.5 screwdriver and pop the black piece off shown here
  3. HTC Warhawk Buttons Replacement: passo 3, imagem 1 %32
    • Take a T5 screwdriver and unscrew the two screws seen here
  4. HTC Warhawk Buttons Replacement: passo 4, imagem 1 %32
    • Unscrew the two screws on the back of the phone with a T5 screwdriver
  5. HTC Warhawk Buttons Replacement: passo 5, imagem 1 %32 HTC Warhawk Buttons Replacement: passo 5, imagem 2 %32
    • Take the SL#2.5 screwdriver and pry off the back cover
    • The phone should now look like the second picture
  6. HTC Warhawk Buttons Replacement: passo 6, imagem 1 %32
    • Take the SL#2.5 screwdriver and lift up the white connector at the top right corner of the phone on the side with the circuit board
  7. HTC Warhawk Buttons Replacement: passo 7, imagem 1 %32 HTC Warhawk Buttons Replacement: passo 7, imagem 2 %32
    • Next lift up the camera lens from the board.
    • It should now look like the second picture
    • Then lift up the circuit circled in red on the second picture
  8. HTC Warhawk Buttons Replacement: passo 8, imagem 1 %32 HTC Warhawk Buttons Replacement: passo 8, imagem 2 %32
    • Take the SL#2.5 screwdriver and pry off the volume buttons on the side of the phone
    • The circuit board should now be detached from the LCD part of the phone
  9. HTC Warhawk Buttons Replacement: passo 9, imagem 1 %32
    • Next take the SL#2.5 screwdriver and pry the buttons off the phone and replace with the new ones
Conclusão
Caitlin Bruce
Membro desde: 10/04/11
23 Reputação
Autoria de 1 guia
Equipe
UW Stout, Team 5-3, Zhou Fall 2011 Membro de UW Stout, Team 5-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 766
