Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The HTC Vive's strap and cables can loosen or fray over time. This guide will show you how to replace the Vive's straps, sound cable, and Three-in-One cable.
O que você precisa
Slide the HTC panel covering the cables forward, away from the Vive.
Gently pull on each of the four connectors to remove the sound and Three-in-One cables.
6 outras pessoas executaram este guia.
3 comentários
What is the name of the Part that holds the strap and has VIVE written on it ? Can I order that part individually ?
You can find that part, as well as the center strap holder by searching on eBay for HTC Vive headset parts. I’ve attached a link here: https://www.ebay.com/itm/Genuine-HTC-VIV...
how to fix my headset strap on my vive i nead some help on it can you show me how.
