Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
The HTC Vive's strap and cables can loosen or fray over time. This guide will show you how to replace the Vive's straps, sound cable, and Three-in-One cable.
  1. Slide the HTC panel covering the cables forward, away from the Vive. Gently pull on each of the four connectors to remove the sound and Three-in-One cables. Gently pull on each of the four connectors to remove the sound and Three-in-One cables.
    • Slide the HTC panel covering the cables forward, away from the Vive.
    • Gently pull on each of the four connectors to remove the sound and Three-in-One cables.
  2. Kit de ferramentas básico para eletrônica
    Kit pequeno. Grandes possibilidades.
    Shop Toolkits
    Kit de ferramentas
    básico para
    eletrônica
    Shop Toolkits
  3. Undo the hook and loop tape on the straps.
    • Undo the hook and loop tape on the straps.
    • Slide the ends of the straps through the hinge loops.
Conclusão
3 outras pessoas concluíram este guia.
Caleb Watts
Membro desde: 25-09-2017
1.584 Reputação
11 Guias de autoria
Equipe
Cal Poly, Team S18-G1, Forte Fall 2017 Membro de Cal Poly, Team S18-G1, Forte Fall 2017
CPSU-FORTE-F17S18G1
5 Membros
11 Guias de autoria
What is the name of the Part that holds the strap and has VIVE written on it ? Can I order that part individually ?
Elias - Responder
You can find that part, as well as the center strap holder by searching on eBay for HTC Vive headset parts. I’ve attached a link here: https://www.ebay.com/itm/Genuine-HTC-VIV...
Ryan Stargell -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 43
Duração total: 1,917
