Introdução
It’s well known that the default head mount for Vive Pro has audio issues, the headphones don’t press enough on the ears so you get faint audio, and the way those headphones are designed, they will fail over time and have to replace them.
Also, the default head mount is a bit loose on the sides and if you do more intense head movements like dancing it will sure come off.
The solution is to replace the default headmount with Vive Deluxe Audio Strap, it was build for the original Vive but can be adapted to fit Vive Pro, it offers better sound quality, no more bulky foams pads, and headset holds better around the head
O que você precisa
Vídeo de Apresentação
You need to 3D print the DAS adaptor pins for Vive pro: https://www.thingiverse.com/thing:389044...
