Introdução
Use this guide to remove and replace the head strap mounts on an HTC Vive.
Ferramentas
Peças
Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
Pull the rubberized grip off of the head strap mount.
2 outras pessoas concluíram este guia.
5 comentários
how do you pute the headset back to getther on the vive.
how do you put the strape back on the right way im stuk i need some help with it.
same man, my headstrap mount and a tracker dongle broke and theres no way to replace it. fml
