Introdução
Use this guide to remove and replace the focus knob on an HTC Vive.
O que você precisa
Use tweezers to remove the small stickers over the four screws securing the outer shell.
Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
Use the flat end of a spudger to pry up the top edge of the right half of the outer shell, behind the component cover and near the seam in the center, until it is unclipped from the headset.
Use a PH000 driver to remove the screw securing the focus knob.
Uma outra pessoa concluiu este guia.
