Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The HTC Vive's facerest may need replacement when it feels uncomfortable against your face or gets dirty. This guide will show you how to replace the Vive's facerest.
O que você precisa
Pull the hook-and-loop (Velcro) closure at the top of the head strap apart to release the top of the head strap.
Slide the top part of the head strap through its metal loop on the headset to remove it.
Pull the hook-and-loop closure at the right side of the head strap apart to release the right side of the head strap.
Slide the right side of the head strap through its metal loop to remove it.
Pull the hook-and-loop closure at the left side of the head strap apart to release the left side of the head strap.
Slide the left side of the head strap through its metal loop to remove it.
Slide the head strap along the cable, away from the Vive.
When the head strap comes to the end of the cable, gently slide it over the plugs and remove it.
Pull the facerest cushion off away from the Vive, separating the hook and loop tape.
4 outras pessoas executaram este guia.
