Ir para o conteúdo principal
HTC Vive Cosmos headstrap Pads Replacement
O que você precisa
  1. HTC Vive Cosmos headstrap Pads Replacement, Remove the rear headstrap pads: passo 1, imagem 1 %32 HTC Vive Cosmos headstrap Pads Replacement, Remove the rear headstrap pads: passo 1, imagem 2 %32 HTC Vive Cosmos headstrap Pads Replacement, Remove the rear headstrap pads: passo 1, imagem 3 %32
    • Grasp the rear headstrap pad on one end and pull it away from the headstrap to remove it.
  2. HTC Vive Cosmos headstrap Pads Replacement, Remove the front headstrap pad: passo 2, imagem 1 %32 HTC Vive Cosmos headstrap Pads Replacement, Remove the front headstrap pad: passo 2, imagem 2 %32 HTC Vive Cosmos headstrap Pads Replacement, Remove the front headstrap pad: passo 2, imagem 3 %32
    • Grasp the front headstrap pad on one end and pull it away from the headstrap to remove it.
    • During reassembly, press the pads firmly against the headstrap, starting in the middle and moving toward the edges, until all the clips on the pads are completely seated in the headstrap. There should be no gaps between the pads and the headstrap.
Conclusão
Adam O'Camb
Membro desde: 04/11/15
196.940 Reputação
Autoria de 416 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 334
