Ir para o conteúdo principal
HTC Vive Controller Saucer Replacement
O que você precisa
  1. HTC Vive Controller Saucer Replacement, Saucer Panels: passo 1, imagem 1 %32 HTC Vive Controller Saucer Replacement, Saucer Panels: passo 1, imagem 2 %32 HTC Vive Controller Saucer Replacement, Saucer Panels: passo 1, imagem 3 %32
    • Turn over the Vive controller so that the bottom saucer is facing up.
    • Use the T5 Torx screwdriver to remove three black 21mm screws from the bottom saucer.
    Pergunte ao FixBot
    Comentar
  2. HTC Vive Controller Saucer Replacement: passo 2, imagem 1 %32 HTC Vive Controller Saucer Replacement: passo 2, imagem 2 %32
    • Use the nylon spudger to separate the top and bottom saucer covers all around the edges.
    • Remove only the top saucer cover by pulling up with your hand.
    Pergunte ao FixBot
    Comentar
  3. HTC Vive Controller Saucer Replacement: passo 3, imagem 1 %32 HTC Vive Controller Saucer Replacement: passo 3, imagem 2 %32
    • Use the Phillips 00 screwdriver to remove the three silver 12.8mm screws from the exposed upper sensor panel.
    Pergunte ao FixBot
    Comentar
  4. HTC Vive Controller Saucer Replacement: passo 4, imagem 1 %32 HTC Vive Controller Saucer Replacement: passo 4, imagem 2 %32 HTC Vive Controller Saucer Replacement: passo 4, imagem 3 %32
    • Carefully pull away the bottom saucer cover with your hand.
    • To aid in removing the saucer cover, squeeze the base of the controller with your other hand, as shown in the second image of this step. Squeezing will make the clips easier to release and help prevent them from breaking.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Ryan Grewohl
Membro desde: 10/02/17
893 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S15-G5, Livingston Fall 2017 Membro de Cal Poly, Team S15-G5, Livingston Fall 2017
CPSU-LIVINGSTON-F17S15G5
4 Membros
Autoria de 51 guias
3Comentários do guia
Where do you get the replacement parts?
dmitri.walker - Responder Compartilhar
Vive dont less these parts we need to 3D print them its a Nightmare RN for business especially arcades
superseani2 - Responder Compartilhar
My controller only has 2 screws that are different sizes than a t5 and the 3rd is completely covered up by plastic. I have the sticky button problem, halp pls
bizkidjordan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 71
Ao todo: 7,203
