Introdução
A quick and dirty, tutorial to get your screen replaced and get you on with your life.
O que você precisa
Move the black slider over to the side without the keyboard ribbon. This is done as to allow the display ribbon to slide out later.
Using a PH 0 screwdriver, remove the 4 screws on the black slider.
Remove the four screws on the back of the screen assembly using the PH #0 screwdriver.
