Ir para o conteúdo principal
HTC Touch Pro CDMA Screen Replacement
O que você precisa
  1. HTC Touch Pro CDMA Screen Replacement, Battery: passo 1, imagem 1 %32 HTC Touch Pro CDMA Screen Replacement, Battery: passo 1, imagem 2 %32
    • First, gently press on the back plate and push down toward the camera.
  2. HTC Touch Pro CDMA Screen Replacement: passo 2, imagem 1 %32 HTC Touch Pro CDMA Screen Replacement: passo 2, imagem 2 %32
    • Use your finger to lift up the edge of the battery.
  3. HTC Touch Pro CDMA Screen Replacement, USB Logic Board: passo 3, imagem 1 %32
    • Remove the 4 screws using the T6 screw driver.
  4. HTC Touch Pro CDMA Screen Replacement: passo 4, imagem 1 %32 HTC Touch Pro CDMA Screen Replacement: passo 4, imagem 2 %32
    • Lift the plastic cover near the memory card slot.
  5. HTC Touch Pro CDMA Screen Replacement: passo 5, imagem 1 %32
    • Remove the two Phillips #00 screws from the backside of the screen.
  6. HTC Touch Pro CDMA Screen Replacement: passo 6, imagem 1 %32 HTC Touch Pro CDMA Screen Replacement: passo 6, imagem 2 %32
    • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
    • Gently pry apart the two halves of the phone.
  7. HTC Touch Pro CDMA Screen Replacement: passo 7, imagem 1 %32 HTC Touch Pro CDMA Screen Replacement: passo 7, imagem 2 %32
    • Gently unplug the connectors.
    • Remove the screws with a 00 Phillips-head screwdriver.
  8. HTC Touch Pro CDMA Screen Replacement: passo 8, imagem 1 %32 HTC Touch Pro CDMA Screen Replacement: passo 8, imagem 2 %32
    • Gently lift the motherboard up using a nylon spudger.
    • BE AWARE OF THE ANTENNA.
  9. HTC Touch Pro CDMA Screen Replacement, Keyboard: passo 9, imagem 1 %32 HTC Touch Pro CDMA Screen Replacement, Keyboard: passo 9, imagem 2 %32
    • Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
  10. HTC Touch Pro CDMA Screen Replacement, Screen: passo 10, imagem 1 %32 HTC Touch Pro CDMA Screen Replacement, Screen: passo 10, imagem 2 %32
    • Start by lifting the back plate of the screen by using yours finger or a plastic opener tool.
  11. HTC Touch Pro CDMA Screen Replacement: passo 11, imagem 1 %32
    • Remove the 4 screws by using a 00 Phillips-head screwdriver.
    • Gently lift the connectors.
  12. HTC Touch Pro CDMA Screen Replacement: passo 12, imagem 1 %32
    • Lift the front keyboard by removing the screws with a 00 Phillips-head screwdriver.
  13. HTC Touch Pro CDMA Screen Replacement: passo 13, imagem 1 %32 HTC Touch Pro CDMA Screen Replacement: passo 13, imagem 2 %32 HTC Touch Pro CDMA Screen Replacement: passo 13, imagem 3 %32
    • With the front keyboard removed, gently lift the screen up with a plastic opener tool and remove it .
Conclusão
3 outras pessoas executaram este guia.
Zhaowei Zhang
Membro desde: 04/28/11
133 Reputação
Autoria de 4 guias
Equipe
CSU Los Angeles, Team 1-6, Nelson Spring 2011 Membro de CSU Los Angeles, Team 1-6, Nelson Spring 2011
CSULA-NELSON-S11S1G6
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 3,629
