Introdução
To replace keyboard.
Peças
Não são necessárias peças.
  1. First, gently press on the back plate and push down toward the camera.
    • First, gently press on the back plate and push down toward the camera.
  2. Use your finger to lift up the edge of the battery.
    • Use your finger to lift up the edge of the battery.
    • Remove the 4 screws using the T6 screw driver.
    • Lift the plastic cover near the memory card slot.
    • Remove the two Phillips #00 screws from the backside of the screen.
    • Insert a spudger or a plastic opening tool into the seam on the side of the phone.
    • Gently pry apart the two halves of the phone.
    • Gently unplug the connectors.
    • Remove the screws with a 00 Phillips-head screwdriver.
    • Gently lift the motherboard up using a nylon spudger.
    • BE AWARE OF THE ANTENNA.
    • Remove the 4 screws circled in red using a 00 Phillips-head screwdriver.
Conclusão
Zhaowei Zhang
112 reputação
4 Guides authored
Equipe
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 1,958
